Stipula 專利的 Netto 墨水塡裝系統
Stipula 專利的 Netto 墨水?裝系統
文章Casper » 3日 6月 2006年, 15:39:57
聽說可以用到最後一滴,網頁還有動畫,但小弟實在駑鈍,不論怎麼樣都看不懂....
貼上來給大家參考,看懂得人,也請說明一下,謝謝
Wonderful clean way for filling all of your fountain pens.
The Netto set comes with the special filling device which Stipula
offers as the "Netto Netto." Netto is Italian for "neat."
Multiple empty bottles in the set allow the user to fill with ink of choice.
These Netto empty bottles are actually the identical bottles in which Stipula Calamo Inks are sold.
Netto is the Stipula patented device that makes possible a clean refill of fountain pens.
The Netto accompanies and completes high quality writing instruments helping them to be practical and easy to use.
The Netto is a system consisting of a small device that screws onto the Stipula ink bottle neck.
This device allows one to fill the fountain pen without dipping the nib and the grip directly in the ink.
The nib will be put in a clean and dry well, where the liquid converges thanks to a multitude of micro-pipes,
by means of the principle of capillarity.
Benefits of the Netto System
1) Filling is clean, rapid and practical
2) Stipula glass bottles in the case can be filled with your favorite ink
3) Micro-pipes allows you to make use of every last drop of ink
4) Your pens will be protected: precious material such as celluloid
cellulose acetate and silver are vulnerable to ink and frequent contact with it can damage their brilliance and color
http://www.stipula.net/use.html
文章小佩 » 3日 6月 2006年, 23:28:39
大致上是說用"導管"的方法上墨,
先把墨水瓶的上方套上那個像"金鐘罩"的東西,
再把筆插入"金鐘罩"頂端,旋轉活塞,就上墨完成。
我想能用完所有墨水的原因在於"金鐘罩"下有個長吸管伸到瓶底,
而插入的筆尖可以藉由這個延伸的吸管把瓶底的墨水吸的一乾二淨。
金鐘罩的筆尖插入只大概是橡皮軟管之類的吧,
可以把筆尖整個束住不露氣,這樣能能順利的吸到瓶內的東西。
使用上會有限制,並不是所有的筆都能用,
只有stipula的鋼筆和所有廠牌的吸墨器能用,
我猜是在金鐘罩口合不合的問題,
使用方法中有說筆尖插入後要順針轉,大概是有用螺紋鎖上吧?
現在的筆廠有似stipula這樣有創造力的還真少見,
仍然想在上墨方式上突破,值得鼓勵,
不過這樣一組東西要賣140多美元真的也蠻嚇人。
https://secure9.nexternal.com/shared/St ... oducts.asp
文章Casper » 4日 6月 2006年, 12:24:03
哦!原來如此,還真是有趣...謝謝小佩小姐的解說,小弟茅塞頓開.....
